11lb Biplane with OS FS52?
I've recently aquired a used biplane and the previous owner said he flew it with an OS FS-70. He said this was a pretty hot plane with that engine. I don't need to to be super hot, so I'm wondering if an FS-52 will have enough power to fly it. I don't know who the manufacturer is and it doesn't look like anything I've seen (could be a scratch built project).
The plane (ready to fly) weighs in at 10.8lb dry. Span is about 55", length, about 50"
Any suggestions or thoughts?
Russ
Russ
NJ
RE: 11lb Biplane with OS FS52?
I just looked in the tower hobbies catalog and found the tiger moth which weighs 10.25 lbs and it requires a .61-.75 2 stroke or a .91 4 stroke. I hope this helps.
I agree with everybody. I have a scratch built 11 pound bipe that has really similar dimensions. I have a Tower .75 two stroke in her. I wish it had a .90 or 1.08 2 stroke instead. That 52 four stroke won't even get it off the ground.
My Feedback: (18)
I fourth that recommendation.
At 11 pounds and being a bipe it would fly like a brick underpowered and with a FS52 or even a FS70 for that matter it would be underpowered.
