Engine mounting bolts
Hi all. I am looking for the part number for bolts with locknuts or such to bolt a TT. 46pro to a nylon mount. They need to be about 1 1/4" long or so.
Shane
Shane
MD
RE: Engine mounting bolts
Hi Shane,
I apologize this a little late. I just got bolts for my TT .46pro today.
I tried 6-32 bolts, but they were a shade to big. I then tried 3mm X 30mm bolts and they fit just great. 30mm is a little shy of 1ΒΌ".
These are the DuBro numbers for the stuff,
DuBro-2127 3mm x 30 Socket Head Cap Screw A little less than 1ΒΌ"
DuBro-2271 3mm x 50 Socket Head Cap Screw Approx. 2"
DuBro-2101 3mm Lock Nut
DuBro-2109 3mm Flat Washer
DuBro-2130 3mm Metric Wrench
I do not know if this will be of any help to you now, but it might be to someone else. I hope.
waynerr
waynerr
