3 switches for 3 batteries?
OK, I'm finishing up my 1/4 scale Byron's CAP21. I've got a 1/4 scale rudder servo, smoke and my RX. The rudder servo is a HiTec 775, and it's instructions say to use a 'y' harness, and give it it's own battery. The smoker is Sullivan Skywriter. It also says to have it's own battery, perferably 6 volt or higher. Finally my RX, which will use a 2800 ma NiMH. Now, if I have my regular switch setup, it will shut off the RX when switched off, but that won't shut off the 1/4 scale servo or the smoke pump will it? So do I need a seperate switch for each one?
My Feedback: (10)
RE: 3 switches for 3 batteries?
Yes and no. You need to at least unplug the batteries or you risk the system feeding unwanted power to the servo or smoke pump.
If you use switches......use charge jack switches. Then at least they serve a second purpose. (my 35% edge has 4 switches, Rx batt....extra Rx batt....ignition....smoke..)
IL
Do you mean 755? I don't see that servo needing it's own battery. The digital counterpart to that servo would be the 5735 which operates just fine from the Rx battery as long as the wire is of sufficient size. I would think the 5735 draws more current than the 755. A better set-up might be two Rx batteries with two switches. This way you have redundancy to the whole system. You will of coarse need a separate battery and switch for the smoke pump either way you go.
ORIGINAL: Stick Jammer
IL
Oops, actually it is the 705MG. It's a big bugger. 177oz @4.8V.
