Englargin Retract Wells in Wing ????
Hi Guys,
Hope someone can give me some adivice i flew my P-40 Today World Models........ but it has twist and turn retracts and the wheels they give u are far too small any little bump it noses over......... so i would like to add bigger wheels....... but the question is How do i go about doing this ???
The 2 Pics below show how it is now, but i want to add bigger wheels so ground clearance will be better.... any suggestions will be extremely helpful
My Feedback: (90)
RE: Englargin Retract Wells in Wing ????
If you do this, the most important thing is" Do Not Cut the Spar". Most warbird ARFs seem to have wheels that are to small, and in most cases cannot be enlarged due to spar location. This my biggest personal beef about Warbird ARFs.
In this case it looks like you may be able to go larger. Just keep wing thickness in mind at the rear of the wheel well.
IL
IL
If your field is bumpy or has ruts, larger wheels won't help much. Even with larger wheels you'll need to follow the correct taxi/takeoff/landing procedure for Warbirds. They like to nose over if you don't. Knowing when to let off the elevator during takeoff is critical. If you let off too soon before the plane picks up enough ground speed, she'll nose over. If you don't let off soon enough, the plane will jump into the air before it has enough speed to keep flying and once the nose is up too high she'll stall and come right back down. Double check and make sure the CG is correct.
