Engine recemmondation
My Feedback: (9)
VA
I have a Funtana 90 and was going to put a Saito 180 on it but I was thinking of trying a gas engine. Not know much about the size can anyone recommend a gas engine that would give similar performance. Is there a chart anywhere that compares gas to nitro?
Thanks!
Thanks!
LA
RE: Engine recemmondation
I own the Saito 1.8 and have seen the F .90. The max reco. engine is a 1.00,, but my plans are to use a 1.20 4 stroke. I would not use a gas burner,, too heavy,, wayyyyyyyyyyyyyy too much power on the big engines. The plane would be too heavy and / or way off CG. To make a really great flier.. use the Saito. 1.2 Jim
Hi, i recently built a kadet with a wingspan of 78in and weights around 5kg without fuel (if i weighed it right). it has got a thunder tiger 61 in it and would not take off on its maiden flight as it kept turning to the left. a more experianced flier said it was overpowered, but did not seem like it to me. please help.
the kadet has only three channels. if anyone can tell me how to post a picture i will.
My Feedback: (16)
BC, CANADA
Hey Pundi,
You should post a new message describing your problem so everyone has a chance to help you
There are a few reasons that could explain why your plane goes left. Chances are it has a lot to do with right engine thrust and or your vertical fin is miss-aligned. Standing behind the craft is your engine turned to the right or left? Also check your fin and make sure it is straight with the fuse.
Although the .61 is a large capable engine, proper throttle control on take off and general flying etc should prove to be a good combo. I would say your trouble lies elsewhere!
That more experienced flyer is an idiot. Two things that come to mind, Flying skill---or do you have any right thrust on the engine, this will help a bit.
ORIGINAL: pundi
thanks everyone i will find the problem and let you know! the more experiance flyer has been flying for 40+ yrs and is used to his own controller and Probably couldnt work out my Modern Controls.
So is there a chance that it might be overpowered.
Can anyone please tell me how to post pictures.
ORIGINAL: pundi
