building question
building question
NEED HELP FAST...
very eager to continue my wing.. so I want to know what I should do...
Here it goes..
I build my wing on a slightly curved suface.. (slightly)....
if this is the wing --> -------------XXX--------------
x is the fuselage...
dashes are the wings...
so my wing is bent like this: the tip.. and the part that's attached to the fuselage are higher than the middle part.. so if I put the wing on a real FLAT suface, then those two sides (the tip and the part close to the fus.) will be up from the ground .. having a distance of 3 millimeters (each)... so If i pin one side to the ground.. then the other tip will be 6 millimeters from the ground.
3 millimeters = 1/16 inch
So my questions are:
HOW BIG OF A PROBLEM IS THIS?
HOW CAN I FIX IT?.. and if I can't or shouldn't.. SHOULD I BUILD THE OTHER WING LIKE THAT TOO?
Thanks a lot for your help, all!
Here it goes..
