TYpe of Servos used For RC-53 Kobra abd its numbers or Product Code
[] Can Any one tell about the type of servos used in Kobra RC-53 And also how to choose the servos used to build Kobra RC-53?
Nanak
Nanak
RE: TYpe of Servos used For RC-53 Kobra abd its numbers or Product Code
ORIGINAL: sunnyin
Nanak
Nanak
If this is the SIG King Kobra (60 size), it will depend on how you plan on flying it. If you will be doing NORMAL sport flying, standard servos will be OK. If you plan on doing ANY HIGH SPEED manuvers, I would suggest standard servos for the ailerons and a MINIMUM of 75 oz torque for the rudder AND elevator.
You choose your servos based on how you plan on flying the plane AND the size of the plane/engine AND the torque rating of the servo. Standard servos are typically in the 45 oz - 48 oz range @4.8 volts.
For aircraft with large control surfaces AND/OR high speed manuvers, you will usually want higher rated servos.
If you are not sure, here is a calculator that will provide the servo size (in oz of torque ) that you will need. http://www.csd.net/~cgadd/eflight/calcs_servo.htm
