Solar activity-affect our radios?
I did a search on solar flares here and found the last discussion was several years ago, which didn't seem to offer anything definitive. Several posts lately mention unexplained crashes, some attributed to solar activity. I've noticed lately some of the FM radio stations I normally listen to are barely audible, or lost altogether. Anyone hazard a guess on this subject as far as currrent equipment goes? As our planes get faster, costlier, and bigger seems there ought to be some scientific evidence as to whether or not solar activity suggests a 'no fly' day. Seems like if solar flares, etc. can block an FM radio station, it would certainly squash our tiny transmission signals.
RE: Solar activity-affect our radios?
ORIGINAL: wsmalley
http://www.n3kl.org/sun/status.html
Solar activity should run extremely low on the list of concerns for RC modelers.
Kelvin
KC0UCK
My Feedback: (32)
AZ
Actually, in a word, YES. It wreaks havoc with our aircraft radios(full-size, HF and Satcom, GPS, etc). Although our RC radios are very well filtered and highly selective, it can - and will create problems from time to time, but by no means is the cause to more than probably 0.1% of crashes.
Most likely, our crashes can be attributed to pilot error/mechanical failure. ( 99.9%)
(Numbers are just a guess, mostly from my own experience-and crashes)
Search for "solar weather", there are some nice sites out there that will explain everything we know about it, and some sites have solar impact forcasts, current solar weather, flare activity, etc. (edit: see above link also) Ooops!
My Feedback: (60)
Mark Pf??? Username Wocketman is a Nasa Rocket Guru responsible for the main booster rocket. He is also an RC Turbine Pilot. He claims it is absolutely 100% plausible and believes one of his first jets was lost to this phenomenon.
I've know Wockman for three years and flown with him on a couple of occasions, have no doubt in his reason.
Sean
Sean
Well I suppose if your bouncing your R/C signal off a satalite.
Or flying during an extreme solar event, at the north or south pole, with a very large plane at the very edge of where you can see it then maybe.
If none of the above apply to you, then concentrate on vibration isolation and proper battery care and you will minimize your radio problems.
So far it sounds like intuitive reasoning but, I don't see any 'scientific' explanation to prove or disprove the idea. I have no opinion other than trying to listen to my radio and something seems amiss. Seems like some pretty experienced fliers say-yes. Granted, other things-like batteries, brain farts, dumb thumbs, may be the culprit, but how do you prove it, one way or the other?
ORIGINAL: wsmalley
It's just that the science suggests that solar interference is unlikely under reasonable comditions. If you want to watch the activity monitors and avoid flying when the levels are high, go ahead, I suppose. I don't expect to ever worry about it, though.
[quote]ORIGINAL: kdheath
Do you have a website for solar flare/radio interference activity?
Cheers!
Jim
ORIGINAL: wsmalley
. If you want to watch the activity monitors and avoid flying ...
Cheers!
Jim
I don't often list credentials however my opinion comes from 12 years as a Naval flight communications operator and avionics tech. I've used and maintained a variety of HF, VHF, UHF, LF, satellite and secure communications equipment including voice, data and TTY. Solar activity generally does not interfere with anything thats LOS (Line Of Sight).
