Balancing your model
When balancing a model, what does one consider "balanced"? I have a balancing tool (Great Planes), but even on that, should it be perfectly level, or maybe just a bit to the nose heaving side? If level, what is considered "level"? Hey, this is a great site!!!
My Feedback: (16)
GA
I set the plane to balance at the recommended CG point then a adjust it depending on how it flies. Lateral balance is very important and many accusations of tip stalling is due to a lateral out of balance.
A nose heavy plane won't fly well and a tail heavy plane won't fly long....sorry, but you opened yourself up for that one. But it is true.
A noseheavy plane loses altitude quickly when you reduce power and lands at a high speed. A tail heavy plane may never give you the chance to try a controlled landing. It will be very unstable as soon as it leaves the ground and will probably stall, spin and crash...depending on how tailheavy it is and your experience level.
