canopy glue?
canopy glue?
I am ready to glue in place plastic buble-canopy. In the past I used acetone based balsa cement. The area where the canopy contacted fuselage was only painted balsa wood. This time the fuse is monocoated. Would the same glue be a good choice? Thanks for advice! Pajda
canopy glue?
They make a glue just for canopy's and it dries clear and thats what you should use. It sticks to just about everything and you clean up with just a bit of wet towel, Its also fuel proof so you will like it plus it looks good not to have screws sticking out of the side to hold it on, like H9 likes you to use.
