n anyone help
n anyone help
Hi, can anyone help, i've got a spitfire with mechanical retracks and i've been told to run a seperate batt for them as the rx batt can be run flat by them? How is this wired up?????????
RE: n anyone help
I have flown several pattern planes with mechanical retracts. The battery drain that you are being warned about is when the servo hangs up. If it never hangs up the current draw is the same as any servo. I have never used a seperate battery pack.
But if you wanted to add a second battery, I would add it to the receiver with a seperate switch, that way you are getting more protection.
tonyc
tonyc
FL
RE: n anyone help
just like any other servo... at each end of travel, make sure the servo is not humming (i.e., it doesn't get hung up). No humming = no current draw
