Avistar with loose covering
Anyone know how to 'tighten' the covering on this ARF? Its Stick-on covering, and it just makes it worse when trying to do it with an iron, I havent tried a heatgun because im afraid it will just melt the covering... and ideas?
Thanks.
Thanks.
I've used a heat gun numerous times with that type of covering you just need to start way back & keep the gun moving until you get a feel for the covering. Obviously you would want to start in a hidden area in case you get it to hot.
You Can Do It,
slim
You Can Do It,
slim
