filling the fuel tank
AZ
I have been flying a plane where i can easily remove the fuel tank and tell when to stop pumping fuel in. But i recentatly got a plane where it won't be so easy to access the fuel tank. I have several times fluded the engine trying to do put fuel in when the wing is on by over pumping. Does anyone have any tips or ideas on how to fill the tank without flooding the engine. thanks
RCU Forum Manager/Admin
My Feedback: (9)
RE: filling the fuel tank
Remove the line that goes to your carburetor and connect you fuel pump to it. Remove the line that goes to the pressure fitting on your muffler and point it to wards the ground. Pump fuel in until fuel starts coming out the pressure line.
Hope this helps.
Ken
Hope this helps.
Ken
ON, CANADA
or take the line from the muff and direct it into a baby food jar. when it comes out that end, stop filling. reconnect. recycle the fuel. no loss. never had a problem with this method (some say the fuel is contaminated. I say my method works just fine).
TX
RCKen--
Related question--
I have been fueling like you described since I started flying last fall. I have also been reading many threads about adding a 3rd fuel line and fuel dots for cowled engines. If you have a 3rd fueling line --- do you just fuel/de-fuel through it or do you also need to remove the pressure line??
Related question--
ON, CANADA
ORIGINAL: mimhoff
RCKen--
Related question--
RCKen--
Related question--
TX
Thanks Voyager --
I am still not sure I get it or maybe my understanding of the 3rd line is wrong.
Wish I was good enough on the 'puter to attach drawing -- but here is how thought the 3rd line was setup:
1 - line between carb and tank (tank line has clunk)
1 - line between Fuel Dot and tank (this tank line also has clunk to assist in de-fueling)
1 - line between tank and nipple on exhaust muffler (the tank line on this is bent up to vent?)
This is how I understand the 3 line system???
Now to fuel I thought you removed the fuel dot from holder - remove dot and fill from fuel can line. If .... this is correct (and I am not sure that I got any of this correct) Where does the "overflow" go??? Out the muffler? or do I still need to remove what I have described as the pressure line the same as I would do on a two line setup.
Sorry -- I just want to get this right.
CA
Get one of these valves. put it inline with the carb and level with the carb and the tank, that is not too critical but it helps.
If you can see the return line on the muffler make sure you get one(fuel line) you can see through then carfully fill untill you see fuel then back the pump off one turn. If you can't see the return line then your only choice is to fill it until ya get fuel out the muffler, its a waste though
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXK135&P=0]fueler valve[/link]
TX
Redfox--
I put one of those valves on my Rascal. I thought it was a pretty neat, clean way of plumbing the engine at first ..... but I had a couple minor issues.
1. The one I had used a special notched fueling probe that would not fit in my fuel can return opening. So I had to make an adapter out of 3" piece of tubing and the probe. Had to try to hang on to my filler adapter, then attach to fuel can line then insert probe in valve.
2. Occasionally, I would remove the probe from the valve and it would stick and drain fuel all over the place. I finally learned to kind of pull the probe out at an angle and it put a little pressure on valve and would close properly.
It lost some of it's convenience because of these reasons.
The third line appeals to me because of no special fittings or valves to deal with. Simple.
Just having a problem understanding for sure how to configure it.
PS -The problem went away(along with the firewall & LG) with just one very poor landing[&o].
GA
ORIGINAL: mimhoff
Thanks Voyager --
Thanks Voyager --
VA
I use an old fuel tank for my overflow rather than a little jar. It has a piece of fuel tubing still connected to it with a short piece of brass tube as a joiner. It requires no aim to get it into the fuel tank and it doesn't splash or spill if it gets knocked over.
TX
Ed-- Thanks alot. I kept getting part of the picture but was not sure I had it straight. I think I do understand it now. I know there are lots of ways to skin a cat -- I just want to get one method straight. I am going to give the 3rd line a shot. I do actually like the idea of the valve but the simplicty of third line has me favoring it.
Mark
Thanks to all.
Mark
Thanks to all.
ON, CANADA
when you get the dot (Bisson makes a good one-either, large or small), it has "plumbing instructions" to show you how to route them. This is what I was trying to describe to you.
http://bissonmufflers.com/en/accesso...ting_id=114508
TX
Voyager--
Thanks a bunch. I already purchased some dots from PSP Mfg that look almost identical to the ones you have shown except they did not come with instructions. I think the schematic answers all my questions. The "T" on the pressure line is the part I was missing. This allows an easy way to deal with the overflow other than running into the muffler. It looks as though you could use a second "Dot" to mange the Overflow line. The diagram just shows just a plug but a second "Dot" would make a clean install. Sorry I am kind of a neatness freak. Thank you very much for posting the picture/schematic -- they are just what I needed.
Mark
Mark
