Aluminum land gear legs
I have broken one of my 1/8" thick alum. landing gear legs on my pattern plane. It sure seems like the 1/8 alum I can buy at Home Depot or Lowes.
my question is - is there special alum that would be better than the stuff I can buy locally or will this stuff be fine for my 11 pound pattern plane ??
thanks in advance...
RE: Aluminum land gear legs
I would sugest you use 2024-T3 the stuff at the box store is probibly 5052 I would make the radous of the bends at least 3/4".
See
http://www.airpartsinc.com/catalog2005_gif.htm
See
As you can see, not all aluminum is created equal.
There are many different alloys (6061, 2024, 5052 etc.) and different Tempers (T-3, T-6).
So your choice comes down to this.
1 - Try the stuff. If it works great, you're good to go. If it doesn't, see #2
2- Buy the correct replacement part.
thanks everyone for the great replies.
this is what I love about our hobby/sport! if only our goverment worked liked this, there would be no cancer, hunger, homeless, etc, etc, I guess I am dreaming..... anyhow....
I've made a set of gear out of the 5024 lowes alum stock, it works great and cost less than 5 bucks for two new legs, compare that to $35.00 for the factory replacement or $50.0 for CF...... I'll go the cheap route and when they break I'll make another cheap set.....
thanks again,
Dean
thanks again,
Dean
Dean if the gear turns out to be too soft or very springy it is easy to fix by laminating a thinner aluminum to the gear. You are correct the government should work with this type of cooperation.
Here is how I reinforced a landing gear.
Bill
Bill
I used two 2-56 button head screws with nuts on the bottom, which can be seen in the pictures. It takes very little to stiffen the gear up. No glue. Originally I thought more screws would be needed but flight tests proved otherwise.
Bill
Bill
TX
now I see. Nice, I'll have to try that trick this week. I have an arf whose landing gear is about as stiff as yarn. I've tried wires, but they keep stretching. This may be the cure I've been searching for. thanks!
