What kind of glue?
MS
What kind of glue?
I have an O.S. .46 LA that I have broken the nipple off of the Needle valve assembly. I received a replacement needle vale assembly yesterday and today I broke the same nipple off while trying to tighten the engine mounting bolt!
Rather than spend ANOTHER $17.00 on another assembly, I want to try to glue the nipple back onto the body. However, I don't know whether to use Epoxy or CA. I believe that I can line the pieces up by inserting a heavy pin that has been greased with petroleum jelly to keep the parts aligned until the glue has cured.
Anybody know what kind of glue I can use?
My Feedback: (13)
RE: What kind of glue?
Try JB Weld. This is a two-part glue like epoxy that is black in color. It is sold at every hardware store in the adhesives section. Comes in two small squeeze tubes. It is a special epoxy that is better on metal and has higher heat tolerance. It is still likely that you will have to be very careful with this part. It will not be as strong as the original.
NC
I doubt that glue or epoxy will work because of the fuel. I would order another. Since it is a remote needle valve assembly you should be able to reposition it so you won't be hitting the nipple when installing the mounting bolt or take the assembly off, mount the engine and put the assembly back on if that's possible.
WCB
WCB
Banned
plastic,whatever happened to the metal ones.been awhile since i bought a new os engine and if they are using plastic i think i will swap to magnum or thunder tiger engines.
My Feedback: (18)
most likely the only option is another needle valve. Vibration is going to be a problem and in the long run fixing it may be possible but it will probably be more head ache than it is worth. I have learned that from experience.
MS
Thanks for the advice. I went ahead and used 30 minute epoxy and it seems to be holding and strong enough. After the first layer of epoxy dried, I added another layer to build it up around the break point. I'm hard-headed and am going to try it. If it doesn't hold, I'll have to get another asembly.
Banned
meatle glue ore 5min epoxy(aroldite)that should do the trick(make sure both surfaces are free of grese and dirt firt ore rough them up with sand paper)
My Feedback: (21)
Hopefully it will hold for you. I don't think that it will last. I broke the ear of of my plastic mount on an LA .40 (where the needle valve assembly was located). The JB just broke off. You would do better to just order a new Carb (with the needle valve on the carb itself).and toss out the old one. I think that OS made a mistake of going to plastic as a back plate, but there are ways to get around that.
