Kyosho GP Ultima ST Question
2 Questions
Here is what always happens:
1. start car, tune, it runs perfectly
2. car suddenly dies while driving
3. car will not start again no matter what i do
4. a day later, car starts fine with same settings
What is going on with me? (i am pretty sure the problem is not overheating)
Second question, the manual says to draw out the gas after i am done, but how do i do that?
GA
how long have you had the car? It may be possible that the engine is starting to have wear on it. This usually causes the car to run good when cold then heat up and loose its consistency.
Another thing you can try is a colder plug. I had the same problem with mt NMT. It ended up being that the engine was to lean after a long period of time and caused some damage. Also check you low end mixture, you may need to richen it up some.
