New (used) GP Piper Cub on floats
ON, CANADA
I bought a used Great planes Piper cub on floats (82 inch wing span) and since I have never flown a float plane, or a cub I was wondering if there is anything I should know prior to the maiden ?
Proper procedure for takeoff ?
Proper procedure for landing ?
What characteristics does it have when it stalls ?
Can you fly it really slowly with floats ?
I love the look of the plane and would like to keep it in one piece.
RE: New (used) GP Piper Cub on floats
ORIGINAL: hancop
>Take off into the wind. DO NOT jam the throttle to full. Increase
>the throttle slowly. Depending on your floats and balance, you
>may need to add A LITTLE up elevator to get it up on the step.
>once it is up on the step, let it build up speed, the apply a LITTLE
>up elevator to break the suction. SMALL waves are a big help.
>If there are no waves/large ripples, taxi around in a circle a couple
>of times to generate some waves/ripples before doing your
>takeoff run.
>Ideally, you want to fly the plane down to about 3" from the water.
>Then start going into a nose high attitude. What you want to try
>to do is is have the back half of the floats (from the step back )
>touch the water first. You will need to keep a higher landing
>speed than if you are landing on ground since the drag from the
>water will slow you down much more quickly than grass will. You
>do not want the tips of the floats to submerge or the plane will
>flip over.
>The plane SHOULD just drop it's nose.
>Yep.
>takeoff run.
>flip over.
>Yep.
Oh yeah. I almost forgot the most important part - make sure you have a boat readily available so you can go retrieve the plane when it decides to play "submarine".
Hope it helps.
What I do on landings is this:
Come in just as you would any other time, but just before you touch down, add just a few clicks of throttle. The throttle won't even have time to give you any more speed, but it will give just a little extra thrust to pull you through the extra drag of the water.
As for take off, keep your wings level! (Same for landings)
