SuperTigre muffler?
RE: SuperTigre muffler?
The following is from the Stuka Stunt Works website at <www.clstunt.com>. Drop Len an e-mail and what he can do for you. The Adamasin mufflers are beautiful and light. The tongue mufflers are the lightest weight of all, only an ounce or so, but a little louder.
Another good source is Scott Dinger at Hy-flo. <http://hyflomuffler.com/contact.html> Scott also is an expert aluminum welder.
CUSTOM LIGHT WEIGHT TONGUE TYPE MUFFLERS
STRAP-ON TYPE TONGUE MUFFLERS
We have custom made strap-on tongue mufflers for those engines that were not originally equipped for mufflers. These mufflers are made to fit snugly over the exhaust stack and are held on by a user supplied strap. I generally suggest using an appropriate sized radiator hose clamp easily obtained at any auto supply store or Wal-Mart.
Strap on tongue mufflers are priced at $21.95 each.
Add $1.00 for a Du-Bro pressure fitting when purchased with muffler.
Strap on tongue mufflers are available now for the OS 30/35S, 40H, McCoy 35 Redhead, K&B 35 Greenhead, and the old Fox 35. Others can be made on request.
BOLT-ON CNC MADE CUSTOM TONGUE TYPE MUFFLERS
We offer oversize CNC machined tongue mufflers made to our specifications that offer a larger chamber to reduce back pressure. These are larger and sturdier than the RSM type of muffler and yet typically weigh only 5/10 to 6/10 of an ounce. These mufflers are available for most engines equipped for a bolt-on muffler (see chart below) and may be available for other engines not listed here. If your engine is not listed, please check before ordering.
Our custom tongue type mufflers include mounting bolts and a DuBro pressure tap. $18.95 each.
BOLT-ON ADAMISIN TONGUE TYPE MUFFLERS
We also offer bolt-on Adamisin type tongue mufflers for most engines including some not listed below.
If you do not see your engine listed, check. If we don't have one, we can get one.
Most Adamisin tongue mufflers include mounting bolts but no pressure tap. $19.95 each.
A Du-Bro pressure tap will be included for $1.00 additional.
CUSTOM LIGHT WEIGHT TUBE TYPE MUFFLERS
ADAMISIN TUBE TUBE TYPE MUFFLERS
We offer custom tube type mufflers made by Art Adamisin that are light, quiet, and non-restrictive.
These mufflers are made to our size and specifications, have a bead blasted finish, and include the mounting bolts and may be tapped for muffler pressure.
These tube mufflers are generally a bit quieter and produce a deeper tone than a tongue muffler, and weigh approximately 1.6 ounces.
Most Adamisin tube mufflers include mounting bolts but no pressure tap, and are priced at $ 29.95 each.
CNC MADE TUBE TYPE MUFFLERS
We now offer a CNC machined (no weld) tube muffler that is even lighter than the mufflers above.
These have a polished finish and an approximate weight of 1.2 ounces.
Our CNC machined tube mufflers are priced at $ 36.95 each.
We normally have bolt on tube and tongue mufflers in the following sizes to fit the following engines:
1 -- 1.378 Fox 35 (50th anniversary), Irvine 36, TT 25 Pro, TT 36, OS 25 BB, Leo 37, Fox 50
2 -- 1.400 Fox 35 (old), FP 35/40, LA 40/46, Tower 40, TT/Magnum 40 GP, TT 42, ASP 46/53 (late)
3 -- 1.455 TT 40/46 Pro, Leo 40/46/51, GMS 47, Magnum 40/46/53XLA, ASP 46/53 (old), ASP 52 (new)
4 -- 1.518 PA 40/51/61/65 SE, ST 46/51/60, Stalker 46/60
In addition we carry bolt on tongue mufflers for the following:
0 -- 1.250 OS 35S (when engine is drilled) 20/25 FP, 25 LA, TT .25 GP, K&B .40, Stalker STM 40 & 46
02 -- 1.100 Brodak 40, Irvine 40 Diesel
03 -- 1.044 Fox 40 Light Case
Other sizes available on custom order.
6-32 thread DuBro pressure fitting is normally priced at $1.35 each when purchased separately.
