Reload this Page >
Robart control horns
Old 09-06-2005, 01:05 AM
HaveBlue
HaveBlue's Avatar
Default Robart control horns
Hi , I need to replace the standard control horns on my F20 propjet. the stock items dont hold up, as a friend who has one, found out the hard way on his fourth flight. I think these look sturdy enough but I am wondering about the tenacity of the ball link and weather these are suitable for speed applications if anyone has used these I'd appreciate any input .
thanks
Old 09-06-2005, 04:29 AM
Countryboy
My Feedback: (25)
Countryboy's Avatar
Default RE: Robart control horns
Well, I sure hope they hold up.... I'm putting quite a bit of confidence in them !!! Seriously, the Robart horns you pictured will be fine on the F-20. Just make sure that where the horns are mounted has a hardened mounting platform. If mounted straight to balsa, harden the surface by wicking thin CA into the balsa first.
ID:	320343   Click image for larger version
Old 09-06-2005, 05:05 AM
HaveBlue
HaveBlue's Avatar
thanks CB, , well checking out the Robart website and seeing that many products are turbine orientated, I'd gather that they will be more than ample for my propjet..turbines are just so cool....thanks for the input
oh yeah and I'll surely take up the advise of hardening the balsa!!!!
Old 09-06-2005, 10:03 AM
Richard L.
My Feedback: (24)
Richard L.'s Avatar
ORIGINAL: HaveBlue
These control horns are very study and will hold up just fine. I'm using them on most of my warbirds.
Old 09-08-2005, 02:02 PM
pcm1024
pcm1024's Avatar
Check out the Chip Hyde control horns from central hobby. they are anodized aluminum and have ball bearings. AWSOME !
I use these exclusivly
Old 09-09-2005, 03:46 PM
HaveBlue
HaveBlue's Avatar
the Chip Hyde control horns look really good and being aluminium, I'm sure will more than do the trick..thanks for the info pcm
Old 09-09-2005, 04:41 PM
pcm1024
pcm1024's Avatar
MY PLEASURE
