need a tip on balsa filler
My Feedback: (38)
I have hobbylite balsa filler, like spackle, but, once it is opened the first time it starts to dry out, how do I keep it usable, it just seems to get dry, I have added water to try to make it more usable again but it gets moldy.
Anyone have a idea?
Anyone have a idea?
I just go to Home Depot and get the light weight spackle as they seem to be the same thing. I also add water to it when it starts to dry out and never had a problem.
Heck I got a jar I bought about seven years ago. I put water in a few times but its still good. How about if you take it out of the original jar and put it in something like an old jar from peanut butter, it might seal better.
Balsa filler
I have been using Bondex Lightweight Spackling Paste from Walmart for small spots, which seems to be just as good as the Hobbylite stuff, but a lot cheaper.
If I have to make a fillet or a large blend in, I use Z-Poxy 30 minute laminating epoxy and Glass Microspheres which I get from a fiberglass shop. The microspheres are the same as microballons, but you can get 1 pound for around $5.
AK
Balsa Filler
I use everything mentioned above, depending on what's required for strength, weight, looks, etc.. One thing not mentioned, although it may seem redundant, is that one of the best balsa fillers is BALSA. For example, when joining wing skins with CA, give the joint a few swipes with a T-bar (sandpaper) WHILE the CA is curing, and the balsa dust will go into the joint quite nicely. I also save balsa dust in a coffee can, and mix it with other adhesives (i.e. epoxy) for filling certain non-structural areas. It's light!
