Large scale CG machine?
My Feedback: (12)
MD
Any helpful suggestions on making -OR- buying a Center of Gravity gadget for larger size aircraft ...1/4 scale and larger..my first home-brewed attempt wobbled and twisted under the weight of the plane. PIC'S would be a great help!. THanks Mikel-T
VA
RE: Large scale CG machine?
The first thing that you could try is slinging it from the rafters in your basement. There was a thread in the warbirds forum of doing it that way.
http://www.rcuniverse.com/forum/m_68.../tm.htm#688627
I use two paint spray cans with two marker pens taped to the top,place one under each wing with the pen in line with the c g and see which way it drops, carefully of course. my planes are relativly small but you could scale it up
The pictures are of a method that I like. Mason twine is not strong enough for a 45-pound airplane. Don’t ask how I know.
Cost: About 20 cents.
Bill
Bill
WY
I have a large one at home that I found here on RCU. I believe the company is Kollar Craft or something like that. I will look tonight to see the name and if I have a web site. I've balanced my Super Flyin' King (see my avistar) which is a 140" ws and weighs about 40 lbs on it with no problems. The legs are about 30" high.
Rich
Wyoming Wind Festival Jan 1 to Dec 31
Rich
Here's how I balanced my J-3 Cub. I know where the balance point must be, so there is a socket head screw threaded into the exact locatiion. Then a crossbar with two prongs, like a nail, fits into the two socket head screws, and the balance is very precise. I fill the tank with fuel, and balance until the wing incidence is at zero to one degree positive.
Sdd photos of balance stand, crossbar, and incidence meter.
My Feedback: (12)
MD
Seems like I have a few choices. Jim that Cub is outstanding and you CG machine is too.
THe idea that RCFury sent along with the dowel seems more of a one-man operation and I want to give that a try.
Looks sort of like the BillS idea on a smaller scale, Bill what are those dark objects on the wings?....weights?
Rich if you find that web site on "Kollar Craft?" pls e-mail, me, I'd like to see it before I try these ideas.
"The stuff you got to do to HANG with the BiG-Boyz"
Balancing in a cradle allows one to lay parts all over the airplane to test different locations or concepts. I use the same cradle on everything from gliders to 30-pound airplanes. When the mason twine broke on the 45-pound airplane I was considering adding two gas engines to the wing of a Big Ugly Stick. It had two 4-pound water jugs attached to the wing (simulating engines) and it only fell an inch on the wheels.
Bill
