cowl questions
RE: cowl questions
ORIGINAL: cotman
Can anyone tell me how much room I need from top of engine to cowl and how much room from carb to cowl. I have clearence now.. just not sure how much I need. Thanks
With a fiberglass cowl you can go to 1/8" on the exhaust.
These are MINIMUM clearances to minimize/prevent warping/melting of the cowl. Obviously, for optimum engine cooling and minimizing warping/melting, you should have greater clearances. There are very few instances I can think of where you would need to go to minimum clearances on a cowl.
