mounting engine
My Feedback: (10)
mounting engine
I mounted my 75 engine in the inverted position on my P-51. Its kind of close when the cowl is in place. My question is, can I lower the engine about 3/4" down. It will be still on the center line of the plane, but lower then center horizonal. Should this pose a problem by lowering it. That way I'll have plenty of room for cowl without buchering it all up. Any advice would be appreciated.
Banned
RE: mounting engine
with the cowl mounted and the engine in the lower position how does the spinner line up with the cowl?what about the fuel tank location.it usually needs to be lowered with an inverted engine installation,if you lower the engine more,where is the centerline of the tank in relation to the centerline of the engine?if all will line up ok the go ahead.
My Feedback: (18)
RE: mounting engine
You will need to make sure all the things that SBD said check out.
I would install the engine at the lower position temporarily and try to run it and see if it does OK.
3/4 of inch seems like a lot to me and I would think you have a hard time getting the spinner to match the cowl if you lowered it that much.
Have you tried rotating the engine a little bit so its not completely inverted (may 30-45 degrees from inverted)? Maybe at an angle the engine will have a little more room because it follows the contour at the top center of the cowl.
