homemade engine test stand?
My Feedback: (18)
I am needing a test stand for engines from .25 to .90 sized. The ones I have seen for sale are really expensive. Anyone have plans for building one?
RE: homemade engine test stand?
Not cheap but good.
http://www.horizonhobby.com/Shop/ByC...?ProdID=JTCTS2
https://shop.mecoa.com/shopdisplayproducts.asp?id=83
also has a couple of different models.
ORIGINAL: Gringo Volador
When I needed to break in larger engines, I finally gave in and purchased a nice J'Tec adjustable stand, which I bolted to a one-foot-square piece of 3/4" plywood. I use a pair of C-clamps to secure it to a deck railing for use. The only thing I wish I had done was cover the plywood with Formica before I mounted the stand. Fuel-proof paint would be good enough....
Good flying,
desmobob
