Question: Trimming plastic spinners
My Feedback: (13)
1 Post
RE: Question: Trimming plastic spinners
I have found one should remove as much material from the "leading edge" of the spinner hole as possible before starting on the "trailing edge" side of the hole. It is a cut a little and measure how it fits against any back plate prop pegs or screw holes. And be sure to remove equal amounts from both sides. I use a Sharpie marker to set the limit of each cut.
My Feedback: (32)
I just remembered this article on how to cut spinners. It's for C/F and fiberglass but works well in this case.
http://www.rcuniverse.com/magazine/a...article_id=528
