Smoke Fluid
Reply
Old 11-02-2005, 10:13 PM
veroaviaor
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Smoke Fluid
Hi all, I've been trying to find out what to use as smoke fluid since ready made smoke fluid is not available in Malaysia.
Could any of you advice what would produce thick smoke and what mixing ratios of each component in the smoke fluid are, so that I can try and find the stuff needed.
I plan to use it with a sullivan smoke pump. A friend of mine used a mixture of concrete foam oil and diesel, the smoke wasn't all that thick and his pump was damaged after 7-8 times of use.
veroaviaor is offline
Old 11-03-2005, 12:14 AM
Rcpilot
My Feedback: (78)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Smoke Fluid
Try transmission fluid and kerosene. 3 parts Automatic Trans fluid and 1 part kerosene. Try different ratios.
Rcpilot is offline
Old 11-04-2005, 02:50 AM
bigchap
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i don't know if this will work but may be worth a try,i know a few people into model trains and instead of the real expensive smoke oil they use johnsons baby oil!it might be worth a look.
bigchap is offline
Old 11-06-2005, 12:30 AM
veroaviaor
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks man. I will try that out and let you know how it goes.
Old 12-01-2005, 05:37 AM
viet-grunt
My Feedback: (18)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In the club i am with some pilots use Diesel fuel ( for trucks ) it works fine
viet-grunt is offline
Old 12-02-2005, 11:52 PM
lpcdefg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Deisel and kerosene works well about 2:1 or 3:1
lpcdefg is offline
Old 12-05-2005, 08:31 PM
veroaviaor
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Thanks a lot. Will try out the mixture in Jan once my plane is ready.
