lusterkote paint
OR
lusterkote paint
I was putting the finishing touches on my super sportster and i began using a new can of topflight lusterkote paint. i gave it a light coat and to my dismay the can spit out the paint in a rough fashion. I had already used several cans of the stuff and i had no problem getting a smooth spray. what should i do to remove the paint? its on monokote and plastic.
My Feedback: (12)
SC
RE: lusterkote paint
ORIGINAL: BirdBoy
Wet sand with 400 grit paper until roughness is gone, then follow the advice of Richard L. You should have a very slick job after that. BE CAREFUL YOU DON'T WANT TO LET THE SPRAY CAN GET TOO HOT!! yOU DON'T NEED IT TO RUPTURE AND CAUSE HARM. Just good warm water and dry water on spray nozzle before spraying so it won't contaminate the paint.
