trimming a Tru-turn spinner?
WI
What is the best way to enlarge the slots in an aluminum spinner to fit larger props? I need to fit a 15/6 APC in a 2-1/2" standard Tru-turn. Is it important to remove exactlly the same amount from each side for balance? Thanks. Randy
CO
spinners
The best way is to make a template and use it as a guide when enlarging prop cutouts......and then rebalanced the spinner.
I use a dremmel to do the cutting.
Regards
Mark
Regards
Mark
My Feedback: (13)
1 Post
I have used the "barrell" shaped dremel bit.... the one that has the S shaped cutting ribs on the side of a cylinder shaped tip. Sorry, I don't have the part number. I have just eyeballed it, taking great care to cut the same amount from each side.
Just custom order it from tru-turn. They will cut it that way for a few extra bucks (between 5-9, but don't remember at the moment).
