Nexstar CG
Old 11-05-2005, 11:15 AM
crawler tech
Default Nexstar CG
Ok here goes. After crashing, rebuilding, crashing and rebuilding,( %$#@&*! trees)[>:] I am trying to rebalance my plane.
The instructions give a CG of 3-3/16 to 3-9/16 which averages to 3-3/8. That part I have under control. What I have a question about is how do you know when the plane is balanced, other than when it falls off the CG machine? Are the horz. stabs. level? Is the bottom of the wing level( mine is flat, trainer). What signifies being balanced?
