Jammed Carburator
Reply
Old 11-29-2005, 05:01 PM
Mchwind Chimes
Mchwind Chimes's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Jammed Carburator
The plane i have was used once, but the guy who had it i guess did nt put flid in the carb before storing it, what should i do to get that loose?
Mchwind Chimes is offline
Old 11-29-2005, 05:39 PM
delman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Jammed Carburator
You can try heat or soaking it in fuel - should free it up.
delman is offline
Old 11-29-2005, 05:42 PM
red head
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Spray some WD 40 in the carb and let it set overnight, that should do it. ENJOY !!! RED
red head is offline
Old 11-29-2005, 10:11 PM
2slow2matter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Make sure you chase the WD 40 out of the engine with lots of after run oil as WD 40 attracts moisture--which will make your bearings rust, and you'll have even more problems..
2slow2matter is offline
Old 11-29-2005, 10:59 PM
Broken
Broken's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
--WD-- Stands for water displacer. I have trouble understanding how it could attract water???
WD-40 history
http://www.wd40.com/AboutUs/our_history.html
Broken is offline
Old 11-30-2005, 09:59 AM
2slow2matter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Spray it on something and leave it outside for a while. You'll see how "WELL" it displaces water. Just going from experience here.
Old 11-30-2005, 10:22 AM
kdheath
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, never, ever, ever, leave WD-40 in an engine. The stuff is a disaster. The best oil we've found for engine preservation is air tool oil. It's made to protect pneumatic grinders and such from the moisture in compressed air lines. A many-year supply is about $5, less at Harbor Freight.
kdheath is offline
Old 11-30-2005, 12:51 PM
piper_chuck
My Feedback: (12)
piper_chuck's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: 2slow2matter
The same will happen with lots of lubricants, but that doesn't mean it attracts water. It's not designed to be a permanent protectant against weather.
piper_chuck is offline
Old 11-30-2005, 12:52 PM
piper_chuck
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: kdheath
Really? You should tell that to the boat racing people. It's been used to flush engines at the end of the day for years.
Old 11-30-2005, 12:57 PM
piper_chuck
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh, and back to the original question, I've unstuck several old carbs by heating them to about 300 degrees. This softens the gum enough to let the barrel rotate. Once it's moving, even a little, pouring in some alcohol (Isopropyl, denatured, or bacardi 151 ) and keep moving it. The alcohol dissolves the gummed up oil. Note that you also should remove the needle and clean the spray bar. I've tried WD-40, but have found that it doesn't remove the gum and the carb ends up sticking again.
Old 11-30-2005, 12:59 PM
Rodney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WD 40 is probably one of the worst things you can leave in your engine. Usually heat will free the carb up, just direct your heat gun on it for a bit and then GENTLY try to work it back and fourth. It will usually free up, if not soak it overnight in some fresh fuel or kerosene and try again. Once free, use any good air tool oil, ATF, Rislone or any after run oil (usually overpriced in my estimation) to keep it free. Again, don't leave WD40 in the engine, it's okay to use it but immediately displace it with one of the suggested oils.
Rodney is offline
Old 11-30-2005, 02:02 PM
britbrat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: piper_chuck
ORIGINAL: kdheath
It may be used to flush water out of the engines, but it is a really lousy lubricant. It is almost entirely a high vapour pressure solvent with a very light lube. It has near zero film strength.
However, in the case of stuck components, the solvent carrier will help get the lube into tight places & free things up. Once free, a normal lube should be applied.
britbrat is offline
Old 12-01-2005, 06:21 PM
Mchwind Chimes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i think heat is the way to go right? how should i head it other then heat gun?
Old 12-01-2005, 06:32 PM
britbrat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Before you get carried away with the heat gun, is it a twin-needle carb, or an air bleed type? The reason for asking is that twin needle carbs will have an elastomer O-ring on the low-speed needle, as well as one on the high-speed needle. Somehow you will have to remove the needles to prevent destruction of the O-rings.
Hmmm ---- but then of course, you can't get it appart. []
Stick the sucker in the oven & bake it @350 for 10 or 15 min. [&:]
britbrat is offline
Old 12-02-2005, 06:43 AM
Mchwind Chimes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok cool that sounds fine.
Old 12-02-2005, 06:45 AM
Mchwind Chimes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how easy is it to get the carb out? (2screws?)
Old 12-02-2005, 07:43 AM
britbrat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
2 screws suggests an air-bleed carb & possibly made by OS or Thunder Tiger. However, to give you the help that you really need, we have to know what kind of engine it is. Somewhere on the casting will be that information, or at least some of the information. Look for something that tells you the name of the manufacturer (OS, or OS Max, for example) & also the engine type, or displacement (46 LA, for example). A pic would really help.
britbrat is offline
Old 12-02-2005, 02:19 PM
Mchwind Chimes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it is an mds .40
Old 12-02-2005, 05:26 PM
britbrat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gawd help ya son.
britbrat is offline
Old 12-02-2005, 11:34 PM
Mchwind Chimes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
why you say that man.lol
Old 12-05-2005, 06:41 PM
JollyPopper
JollyPopper's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was not aware that the WD in WD40 stood for water displacement, but I am here to swear that near the end of my working life, I became associated with an automobile detail shop. By that time, most engines had lost distributors, but of the few that came into the detail shop, about 99% of them would not start after being sprayed with a high pressure washer. The guys would pop the cap off, spray a couple blasts of WD40 inside it, pop it back on, and the car would start---EVERY time. Never failed. I still don't believe it. This was in a dealership, so we don't know what happened to the cars in the long term, but it got cars started that had flooded caps. I swear. Don't bad mouth me 'til you try it. It works............
JollyPopper is offline
Old 12-07-2005, 02:44 AM
BigWes
BigWes's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow! I can actually help here a little maybe. WD 40 is a no-no in my opinion. It is a good penetrant for the most part but it is NOT a good lube. WD-40 has a light-weight acidic compound which allows it to break down light corrosion. Imagine if you will putting acid on rust. It will dissolve the rust first thereby breaking it free. Many penetrants work by using acidic or base compounds. And they work good for what they do. BUT, acidic compounds strip the metal surfaces of lubricants-protectants and leave them vulnerable to moisture evasion which inturn allows corrosion--or rust to come back. So, I would say use break free or WD-40(if you must) on the carb and as soon as you get it free then lube it with a light weight oil. I really like break-free, 3-in-1 oil, any mil-spec CLP, and my favorite is a product called corrosionX which does have a base component which will nuetrelize any acidic reactions. Look, if you were to use WD-40 on a real aircraft the first indications would be it worked great. Let it set for a while and the stuff will gum-up. That is a fact. As far as using it on a distributor of an automobile anyone who knows anything will tell you that petroluem base products do NOT conduct electricity. So if you were to take 10W-30W motor oil under pressure and spray it into that distributer cap it would have the same effect as the WD-40. Just much more messy. Don't get me wrong, WD-40 is good for squeeky hinges and bicycle chains, not model planes Or real planes for that matter. I had the almost the same thing happen with me and a model engine. I had my OS 40 LA in storage and the carb barrel was stuck when I finally pulled the plane down a year and a half later. I was ill about it but really it was my own fault. I just put a few drops of fuel on top of the barrel and let it sit. As it would dry out I would put more fuel on it. I worked it loose over a period of time with no harm done. I did spray some corrosionX on it though as I new it would penetrate far deeper than fuel would. After I got the barrel mobil I took the carb apart and cleaned the barrel with green scotchbrite taking care not to be too rough with it. Anyway, now the carb works great. The OS 40 LA is still a gutless piece of crap but the carb works great though
But I agree with everyone else here about the WD-40. It is a good product you can get at any grocery store at 1 AM but the need you are addressing is a little out of its capabilities unless you want to do serious follow-ups with other products. Don't rely on it for glow engine work.
Wes
BigWes is offline
Old 12-07-2005, 06:47 AM
Mchwind Chimes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks a lot you guys, you have been good help.
Old 12-07-2005, 10:49 AM
jessiej
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have used WD-40 for a variety of ourpodes for many years. Good at "water displacement, pretty good solvent and penetrant. Terrible preservative, and short lived as a lubricant. I have a rather expensive reloading press that had been stored after being liberaly sprayed with WD-40. Never again.
A number of excellent after run oils have been mentioned in this thread.
Sometimes mentioned is the venerable household oil Three -In- One. Perhaps the formulation has changed from time to time, but I recently disassembled a few fishing reels which had been oiled with that product several years ago. The oil had congealed into a gummy substance.
jess
jessiej is offline
Old 12-07-2005, 03:29 PM
mscic-RCU
mscic-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Take carb off of engine, soak in fuel. Problem solved.
mscic-RCU is offline
