Third line from fuel tank?
I've built several World Models ARFs and the plans always show three lines coming from the fuel tank; I've always used only two: one for the carb and one to the muffler. Can anyone tell me what the third line is supposed to be for? Thanks. Jack
PA
Use of a third line means that you don't have to pull the fuel line off of your needle valve inlet in order to fill the tank. If you choose to set up a third line the pipe inside the tank must go down to the bottom in order to be able to drain the tank. Some people install a second clunk, instead. The fill line must be closed before running the engine in order to maintain tank presssure.
Dave Segal
Dave Segal
fuel/defuel
Hi Jacktip.
On engine installations where the fuel line to the carb is inaccessible such as an in-cowl install, the third line is routed to the bottom of the tank. The other end is terminated in a conveniently located fuel dot. Fueling and defueling is then accomplished through this third line. Ok?
TX
Any time I have an engine installed that is a problem to drain the engine or fuel /unfuel the tank[inverted or inclosed engine] I use the third line.One end with a fuel dot, the other end in the tank with a clunk on the end.
