Sig Something Extra HELP
Reply
Old 12-06-2005, 04:51 PM
reddog076
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sig Something Extra HELP
I picked up a sig something extra at a swap shop a few years ago and I am now trying to set it up to fly again. Does anyone have the control throws and balance point for this plane?
reddog076 is offline
Old 12-06-2005, 05:40 PM
tonystro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Sig Something Extra HELP
ORIGINAL: reddog076
reddog076,
I believe you can get the throws and cg point, plus a lot of other hints and tips in these threads --
in the RC Kits fourm --
http://www.rcuniverse.com/forum/m_32...2Cextra/tm.htm
in the beginners forum --
http://www.rcuniverse.com/forum/m_3274319/tm.htm
If not, I'll dig out my manual and look them up for you.
tonystro is offline
Old 12-08-2005, 09:10 AM
reddog076
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tony,
Thanks, there's alot of info there
Old 12-08-2005, 10:41 PM
*JCB*
My Feedback: (9)
*JCB*'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
balance point is on the main spar - and i just eyeballed my contol throws...i started with short movements and then cnaged it to my style of flying after the first couple of flights, it can be very sensitve, so start small
*JCB* is offline
Old 12-09-2005, 08:57 AM
reddog076
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 12-11-2005, 02:00 AM
Botle Rocket War
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you use the specified control throws from the manual, it would be a good idea to cut the high and low rates in half for your first flight. Their initial settings are usually a little too much unless you're used to a plane like the SE.
The CG can be moved pretty far in either direction without much issue. The wing spar (that tube) is a good starting point. For the first flight get it within 1/4 of an inch of that spot. All of my Somethin' Extra's were tail heavy with .46's, so you may need to move some stuff towards the front for the initial flights.
You will love that plane! It's one of my all-time favorites.
Botle Rocket War is offline
