Futaba receivers
Reply
Old 12-09-2005, 06:59 PM
conchohoncho
My Feedback: (120)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Futaba receivers
I am confused about Futaba receivers. I have a 7 channel R127DF and an 8 channel R148DF. They both look the same to me. That is they have 7 servo slots and a battery slot. On the 148 it says 8/B, and I don't understand that. Can anyone help?
Richard
conchohoncho is offline
Old 12-09-2005, 07:25 PM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Futaba receivers
Yes, they use the same case and the battery port (which can be any slot) is also channel 8.
ORIGINAL: conchohoncho
Richard
Geistware is offline
Old 12-09-2005, 07:41 PM
conchohoncho
My Feedback: (120)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I still don't understand. I can only use 7 servos if I put the battery into one of the slots. How do you get 8 channels out of that?
Richard
Old 12-09-2005, 08:05 PM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you need all eight channels use a "Y" cord plugged into the #8 or any of the servo ports then in the tails of the 'Y' plug the servo and the power lead from the switch in the other tail.
This is common with a number of various brands in some Rx's.
John
JohnBuckner is offline
Old 12-10-2005, 08:08 AM
Geistware
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Any port can be a battery port. THE battery uses the black and red wires only and all are in parallel. THE white wire is the signal wire and is what the servos use to know the needed controlled position from the receiver. If you have 8 servos, then all will go into one or more of the slots. If you need two servos or a servo and a battery to go into one slot, then you use a "Y" connector which is a cable with one male and two female ends.
Richard
Old 12-10-2005, 12:56 PM
conchohoncho
My Feedback: (120)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the help . I finally understand.
Richard
Old 12-10-2005, 01:28 PM
pt19 flyer
pt19 flyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi
on the slot in question you can can channel 8 by using a y harness to connect the battery and a servo. assuming you have an 8 channel transmitter.
good luck and happy flying
pt19 flyer
pt19 flyer is offline
