Glow Plugs
Reply
Old 12-12-2005, 06:07 PM
crashbandicoot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Glow Plugs
Today I burned out 4 glow plugs in a matter of 15 minutes. I was working on my magnum 52 on the bench. Could anyone tell me the cause?
crashbandicoot is offline
Old 12-12-2005, 06:15 PM
bubbagates
My Feedback: (32)
bubbagates's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Glow Plugs
Too lean, bad fuel, wrong plug
bubbagates is offline
Old 12-12-2005, 06:18 PM
DMcQuinn
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is the element (the coiled spring) destroyed? If so, probably you are too lean / too hot.
DMcQuinn is offline
Old 12-12-2005, 06:20 PM
PropSpinner
My Feedback: (15)
PropSpinner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Need more info.
What kind of plug are you using?
What are you using to power the plug?
What kind of fuel?
Are you removing the glow starter once you get the engine started?
Is there any way you are way to rich or too lean?
PropSpinner is offline
Old 12-12-2005, 09:28 PM
depfife
My Feedback: (14)
depfife's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The only time I went through that many plugs was early in my RC career when I used a glow plug clip plugged into a power panel. Glow plugs don't like it when you mistakenly plug the clip into the 12v starter plug. [sm=bananahead.gif]
depfife is offline
Old 12-12-2005, 10:02 PM
PropSpinner
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Leave it to a Bama boy to come up with a simple answer! That's probably the problem.
Old 12-12-2005, 11:25 PM
2slow2matter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Probably not. Had the glow plugs been conected to 12 V power, he'd have gone through 4 of them in about 4 seconds, not 15 minutes. Sounds like more of a fuel mixture problem, or too much nitro.
2slow2matter is offline
Old 12-14-2005, 11:41 AM
crashbandicoot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am going to go with the lean theory for now.
Old 12-14-2005, 01:24 PM
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hobbico had a batch of power panels go out that have 12v on the glow driver output. The plugs wouldn't burn out in seconds but they whistled when hooked up to power and didnt last too long but you could start and run the motor on them once or twice.
BarracudaHockey is online now
Old 12-14-2005, 01:48 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You might try a different brand of plug?
Enjoy,
Jim
w8ye is offline
Old 12-14-2005, 03:19 PM
Rodney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you are using a power panel, that could be the problem if you have the dial turned to high. I don't know if you realize it or not but a power panel puts 12 volts to the plug for about 1 millisecond then nothing for the next 9 milliseconds. When you turn up the dial that 1 millisecond time period is increased and can be increase enough to burn out the plug. If you are using a battery for the glow starter, then I'd suspect to lean a run. Another possibility, did you put any additives into the fuel. some additives can be destructive to glow plugs.
Rodney is offline
Old 12-14-2005, 07:09 PM
PropSpinner
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I always start with an O.S. #8.
Old 12-14-2005, 09:44 PM
Flypaper 2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Plug heat range is way to hot.
Flypaper 2 is offline
