.60 Lanier Stinger balance help
Reply
Old 01-04-2006, 07:16 PM
David Shaffer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default .60 Lanier Stinger balance help
Dear RCU,
I have a question for anyone who has built the .60 size Lanier Stinger kit. Has anyone out there ever balanced the Stinger without adding a lot of lead to the tail to achieve the correct baance point? The initial balance range is from 5" - 5 1/2" behind the leading edge. I set the plane on my balance stand set for 5" and it is way nose heavy. While building the plane, I even mounted my 2 elevator servos as close to the tail as I could thinking it would help achieve the correct balance without adding a ton of lead to the tail. I'm thinking about moving my battery back into the tail to help, but I dont think that will do very much, and I will need a really long extension to reach the switch. Does anyone have any suggestions to make balance easier to achieve? Any help would be greatly appreciated. Thanks !
David
David Shaffer is offline
Old 01-04-2006, 08:18 PM
LSP972
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: .60 Lanier Stinger balance help
There is a guy on RCGroups complaining that his big Stinger needs 1.5 POUNDS of nose weight to balance.
Sounds like there's not much consistency in materials in those things...
LSP972 is offline
Old 01-04-2006, 08:32 PM
jlank
jlank's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah I can't figure what's making my 120 Stinger so tail heavy.
Joel
jlank is offline
Old 01-04-2006, 09:36 PM
rc-sport
My Feedback: (12)
rc-sport's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
David, what motor are you using? I had a stinger with an old Saito 80 in it, I had to add lead to the tail. I'd say move servos to the tail instead of adding weight.
rc-sport is offline
Old 01-04-2006, 09:52 PM
Kimhoff
My Feedback: (22)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The balance point on my 60 Stinge ARF is 4 to 4.5 inches. If I recall some of the manuals had an error in the balance point. I would suggest you call Lanier and validate the CG.
Kimhoff is offline
