Robart Retract Pressure Gauge
My Feedback: (10)
I'm installing a Robart Air Retract system on a plane of mine; besides the Robart Pressure Gauge which I don't care for, reminds me of an automotive tire pressure gauge, are there Pressure gauges available that feature a dial and needle indicator that I can use on this system.
The gauge will be mounted in an access compartment and the problem I can see with the Robart gauge is that the compartment will not be that deep, and the Robart Gauge extends to indicate pressure much like the Automotive tire gauge; there may not be enough clearance when this gauge is extended and the compartment hatch is closed.
Unless someone can tell me how far do these Robart gauges extend. Thanks.
