Dubro Pull-Pull 2-56 kit question
My Feedback: (14)
How many of you have used this kit? I'm having a problem with the crimps. Now, years ago, I flew CL, so I know how to make cable loops, but back then, we never had "coated" wire to use, and for the life of me, I can't get this cable through the crimp 2 times, let alone the traditional third, then crimp. Do you need to strip off the plastic coating? I finally broke down and tried that, but this braided cable is a major pain to cut and keep in one piec to fit though them itty, bitty holes! I'm just wondering if some larger crimps are needed, or maybe just say bag it and go get some 50# spiderwire fishing line at Walmart. Any Suggestions?
Thanks!
Thanks!
RE: Dubro Pull-Pull 2-56 kit question
Never felt the need to pass the cable thru the tube 3 times. Two, with a hard squeeze has always worked for me.
And when I run out of the supplied tubes, I use 1/16" ID brass.
I've heard that the cables should be crossed under the crimp, not side by side but I'm with you I like the third pass ( loop ) and crimp so I cut new crimps and use them. ENJOY !!! RED
