UltraCote Paint and Fiberglassed Surface
This has more than likely been asked a million times, But here go's. I just finished fiberglassing a set of floats and I wanted to try the UltraCote to match the covering on the plane. I'm not as much worryed about the color match as I am the paint cureing and not bubbleing up or doing anything else strange. I used UltraCote once on a glassed cowl awhile ago and it never did cure all the way. It stayed wet for ever and as soon as the glow fuel got to it, it just wiped off.
I put a lot of time into this plane and I don't want it coming out "Jacked" up because of trying to use this raddle can paint. What luck have you guys had?
RE: UltraCote Paint and Fiberglassed Surface
Vicman, You do nice work for such a young guy .
krossk, I have seen some of your covering.[sm=thumbup.gif].
You know I covered my last 2 sets with Ultracote covering and they came out real nice. I guess I could just cover these too. The thing is with floats a tad of dirt-sand with water starts getting under a little tiny piece then it starts comeing up, and the rubbing on the sand-dirt beach surface doesn't help any either. I don't know???? I hate to spend 80 bucks on a special mixed to match auto paint. And I would really hate to have the Ultracote paint job turn sour on me. Ummmm[&o]
My Feedback: (27)
WI
In that case, why not cover them with the matching ultracote and then spray them with a durable clear finish - perhaps Clear ultracote or automotive polyurethane? (Just be sure to use the proper respirator - that poly-U is some nasty stuff)
