Sealing Towerkote/Monokote seams
WA
What if anything do you guys use to seal the seams of your plastic iron-on coverings? I have never used anything and it seems that my covering always peals back after awhile. Thanks for the help.
NE
RE: Sealing Towerkote/Monokote seams
I've only covered one plane, but per the advice of others on RCU I bought some trim solvent & went over the leading edges of my graphics with a Q-Tip. so far so good.
My Feedback: (9)
TX
That's a pretty good tip tuwood. Acetone is a lot cheaper and it still gets the job done. I like to wait a day or so after covering then seal all the seams. A very small amount is all it takes, too much is not better.
WA
Thank you all! You are a wealth of information. I think I'll try the nail polish or clear dope. My dad recommended clear dope also. I can't use CA because I'd be afraid of it dripping through the seam and into the foam wing.
Can someone explain how the Acetone would work to seal the seams? I would think that it would only clean up the edges.
Thanks!
Thanks!
I have built lots of models and I have never had any problems with the seams separating.You should not need anything to seal the seams.Monocote on top of monocote stick extremely well.
MA
I read in a forum last year about this subject. Someone was using Minwax Wipe-on poly. I started using it on all my planes and it has worked great. I just apply it with a Qtip. Never had a problem.
Bob
Bob
