Bonding foam? spray glue/CA/epoxy?
Reply
Old 02-22-2006, 03:57 PM
flyinryan2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bonding foam? spray glue/CA/epoxy?
I"m bonding 4 peices of 3/4" foam together for a project I'm woriking on. What is the best way??? I'm thinking 3M spray glue. What do you guys suggest. The pieces I'm making will be 3"x4"x36".
Ryan
flyinryan2 is offline
Old 02-22-2006, 04:13 PM
blueline
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Bonding foam? spray glue/CA/epoxy?
Foam safe CA works, so does spray adhesive and or contact cement which is what 3M is in an arosal form. Its just your preference.
blueline is offline
Old 02-22-2006, 05:30 PM
oscar2005
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
be careful of the 3m spray as they have changed the propellant and it can dissolve foamtry it on a test piece first.
oscar2005 is offline
Old 02-22-2006, 05:33 PM
kahn41
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
3M-77 will eat the foam but not to bad if you spray a little at a time!
It worked for me .
kahn41 is offline
Old 02-22-2006, 07:31 PM
boiler1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
3M 78 is designed to bond foam. It works very well. Polyurathane glue works good also (Gorilla glue, Elmer's ultimate glue, Titebond polyurathane). Epoxy tends to be more expensive and troublesom but will work fine. All should give a good strong bond.
boiler1 is offline
Old 02-23-2006, 01:12 PM
FLYBOY
FLYBOY's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
anything you use is stronger than the foam, just make sure it is light.
FLYBOY is offline
