building board ?
Reply
Old 02-27-2006, 10:09 PM
extra1968
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default building board ?
Hi
Do yall think a cheap door from lowes would make a good building board if i sat it on a flat workbench ?
Have not built a kit in about 15 years .
extra1968 is offline
Old 02-27-2006, 10:13 PM
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
RCKen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: building board ?
extra1968,
A 2'x6' hollow core door makes an excellent building board. They are very flat building surfaces and they are usually pretty cheap. Ask them if they have one that is damaged. Usually the damage is on one side and you can use the other side. They will usually sell the damaged door very cheap (I picked one up for $5).
Hope this helps
Ken
RCKen is offline
Old 02-27-2006, 10:15 PM
JCOKEEFE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[8D]I've used them for years. Look for a luan sheeted, hollow core door. Check to be sure
that they are true, i.e., not warped. Most are straight and level with a nice smooth finish,
and easy to stick pins into. Home Depot most likely sells them, also. They should be
available in the $20-$25 range, give or take a few dollars.
JCOKEEFE is offline
Old 02-27-2006, 10:17 PM
extra1968
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what about push pins (t pins) ?will they work ok with the door?
Old 02-27-2006, 10:43 PM
JCOKEEFE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, no problem.
JCOKEEFE is offline
Old 02-27-2006, 10:51 PM
RCKen
My Feedback: (9)
RCKen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, you can push the t-pins through the door. Here's a tool that will save your fingers as you work. [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXK358&P=7]Great Planes PinDriver T-Pin Pusher[/link]
Or if you want you can get a ceiling tile to put over the door to push pins in. The door will keep the tile flat and level and the tile will let you put pins in. Before I built my magnetic building system I put the pins directly into the door.
Hope this helps
Ken
RCKen is offline
Old 02-27-2006, 11:00 PM
tashley
My Feedback: (9)
tashley's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's a great building board. I still use one to this day. If you check Lowes you can find one that is pre-primed.
tashley is offline
Old 02-27-2006, 11:03 PM
Dr1Driver
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Extra,
Top the door with ceiling tiles, then top that with cork. The cork is easily replacable and it and the tiles are easy to push pins into. The tiles will last a long time before they need replacing.
Dr.1
Dr1Driver is offline
Old 02-28-2006, 04:54 AM
RevGQ
RevGQ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I too think that hollow doors are great, but why buy? I usually find them behind door shops ready and waiting for the trashman.
RevGQ is offline
