Hotwire cutting templates
Reply
Old 02-28-2006, 10:49 AM
Brian Blazer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hotwire cutting templates
Can I use steel or aluminum templates for hot wire cutting?
thanks,
Brian blazer
Brian Blazer is offline
Old 02-28-2006, 11:08 AM
Teachu2
My Feedback: (133)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Hotwire cutting templates
I use Formica (plain, no backing board attached) and am very pleased with it. I buy a 2'x4' panel at the lumberyard. Easy to cut with a scroll saw, then finish with sandpaper. Aluminum would be OK, but harder to work with. Steel would be too heavy IMHO, as you need the foam core to support the templates.
Teachu2 is offline
Old 02-28-2006, 11:46 AM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Either will work fine. To me the most important thing is that they have a smooth surface so your wire doesn't get hung up.
MinnFlyer is offline
Old 02-28-2006, 12:34 PM
Lightfoot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have used formica and aluminum. The only problem I had with the aluminum was that it acted as a heat sink and drew some of the heat from the cutting wire. This caused the wire to drag through the ends of the cut leaving the edges a little rough. I prefer formica because it is more readily available at a good price (free) and is easier to work with.
Lightfoot is offline
Old 02-28-2006, 01:39 PM
Brian Blazer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys,
I am building a fixture and wanted to make sure steel or aluminum would work and not act too much like a heat sink. I have access to a laser so making the templates won't be a problem. The parts I will be making are small pontoons (2"x13")
Thanks again,
Brian
Old 02-28-2006, 05:32 PM
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi! Formica is best!
Steel or aluminum should be avoided as they steal lots of heat from the wire which will tear up the foam edges.
Regards!
Jan K
Sweden
jaka is offline
Old 02-28-2006, 05:44 PM
kahn41
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree with the above post's avoid aluminum and steel!!!
kahn41 is offline
