Easy Star Electronics Troubleshooting.
TX
Bought a Multiplex Easy Star ARF. Using the stock motor and propellor. Purchased a Pixie 20 Amp ESC and GWS nano receiver. The receiver came with a crystal. As I requested, the receiver is coded F for negative shift to work with the transimtter I already have. (3-CH Futaba that comes with the Hobbico Superstar). Got all the electronics wired up and...
I turned on the radio. Then I hooked up the battery. The motor emits a continuous beep. According to the troubleshooting guide, this means it's getting no signal. I played with the throttle. I even tried hooking to all the different channels on the receiver. No dice, just continuous beeping. The wire colors match so I don't see a polarity issue.
Any thoughts?
Any thoughts?
