Saito 120 and 10mm shaft
Reply
Old 03-04-2006, 11:20 PM
thomp896
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Saito 120 and 10mm shaft
I have a Saito 120 mounted on my Skybolt and am ready to get her in the air this spring. The crankshaft on this beast is 10mm(I think) and I can't find a prop reamer big enough. All my drill bits are standard and I'm afraid to use a drill anyway due to balance issues. Is there a reamer out there anywhere for the larger diameter shafts? What do all you guys who fly the big gassers do? Thanks, Steve.
thomp896 is offline
Old 03-05-2006, 12:16 AM
ArCeeFlyer
ArCeeFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Saito 120 and 10mm shaft
I have the same engine. Great Planes makes a 10mm reamer and its very high quality. Just make sure to keep it oiled when stored. I spray WD-40 in the plastic container it's kept in. I use a drill press for accuracy. I also use a 25/64 drill bit to drill the hole first then ream the last bit out with the 10mm reamer, using the drill press of course.
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXEGH6&P=0]Tower Hobbies / GP metric prop reamer[/link]
ArCeeFlyer is offline
Old 03-05-2006, 04:36 PM
thomp896
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you very much for you help that is what I will do!! Thanks again, Steve
thomp896 is offline
Old 03-05-2006, 07:32 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fox makes one also.
http://www2.towerhobbies.com/cgi-bin...?&I=LXNL18&P=7
I have the Great Planes. It is first class.
Enjoy,
Jim
w8ye is offline
