KANGKE WACO
Reply
Old 03-05-2006, 01:56 PM
Buteos
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default KANGKE WACO
When I assembled my Waco I noticed two things in the rear control surfaces. First when you install the servos in the rear for the elevators and install the cable for the rudder the cables come in contact with the lower part of the servo housings on the inside of the plane. Secondly the control horns for the elevators and the horns for the rudder come in contact with each other during extreme movements, ie. left-down, right-up, etc., etc.. The servo tray is at the rear most postion and I am using a 2" control arm on the rudder servo with the stock cable system including the turnbuckles. I have moved the horns in my attempt to elminate the problem to no avail.....any ideas from those of you who have built this plane????
Buteos is offline
Old 03-07-2006, 05:06 AM
flatspin1b
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: KANGKE WACO
I put a 3/32 ply shim on each servo......that fixed it.
flatspin1b is offline
Old 03-07-2006, 06:46 AM
Buteos
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So you shimmed them farther out......?
Buteos is offline
