Reload this Page >
*Adjusting The High Speed Needle Inside A Cowl*
Reply
Old 03-07-2006, 06:47 PM
Zippi
My Feedback: (10)
Zippi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default *Adjusting The High Speed Needle Inside A Cowl*
Does anyone have a pic of something that has been made up to adjust the high speed needle valve through a cowl? This is on the new OS 120AX. It comes with a small dia. wire and thumb screw to attach to the needle valve but with the needle valve being slanted it makes it difficult to take the cowl off and on in this application. I need to be able to just stick something through the cowl and attach to the needle valve to make the adustment and then remove it.
Zippi is offline
Old 03-07-2006, 07:05 PM
bbbair
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: *Adjusting The High Speed Needle Inside A Cowl*
Correct me if I'm wrong - but that wire and thumb screw should attach to the high speed needle.
On most engines of that size there is a hole drilled into the HS Needle, and on the side there is a small Allen head screw.
-Back off the screw, insert the wire and tighten the screw back up,
-Now see how much of the wire is needed to exit the cowl (about 1/4" outside of the cowl), trim to suit.
-Attach the thumb wheel - it should have an Allen screw too.
Now drill a hole in the cowl to accommodate the Thumb wheel and install the cowl.
Problem solved!!
bbbair is offline
Old 03-07-2006, 07:21 PM
Zippi
My Feedback: (10)
Zippi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, the wire and thumb screw attach to the high speed needle but I was looking for another option as stated above. Thanks anyway.
ORIGINAL: bbbair
Problem solved!!
Zippi is offline
Old 03-08-2006, 12:37 AM
Gremlin Castle
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Grind the threaded area of a 4-40 or 6-32 socket head capscrew down to the wire size and stick it in the needel valve instead of the wire. Then stick a ball driver down thru the hole in the cowl into the socket head to adjust the needle valve.
Been using that method for the last 15 years with no problem.
Gremlin Castle is offline
Old 03-08-2006, 05:41 PM
Zippi
My Feedback: (10)
Zippi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Now that's what I was looking for . Thank's for the info Gremlin Castle.
ORIGINAL: Gremlin Castle
Zippi is offline
Old 03-08-2006, 07:47 PM
daveopam
My Feedback: (9)
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just did one kind of like Gremlin said. Instead of grinding the bolt down I drilled and tapped the end of the high speed needle. Then Loc-tighted it and put the set screw back in. I can get the ball driver in then run the motor up and tach it. Works great.
David
daveopam is offline
