Reload this Page >
os91fs and palmer plans
Old 03-12-2006, 03:46 PM
robp
Default os91fs and palmer plans
Has anyone out there had anyproblems with there 91 breaking the value springs. I have two now in last couple years. I 'm wondering if they aren't getting brittle now. Going put new in both engines for security any way. Also has anyone worked with palmer plan guy. I e-mail him but do not get straight answer from him. Trying to find if buying his c-119 plans can get the wood cut some place who has cad for these plans.
R Palmer
NO KIN
Old 03-13-2006, 04:10 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Default RE: os91fs and palmer plans
I've been around a lot of OS 91 Four strokes. No one has talked about breaking valve springs. I've had one about four years.
You may be running them too fast? What prop are you using? should be 13-8 or 14-6?
Enjoy,
Jim
Old 03-13-2006, 04:28 PM
TLH101
My Feedback: (90)
TLH101's Avatar
Checkout rcscalebuilder.com. There is a forum for Palmer Plans, and a build thread specific to the C-119.
Old 03-13-2006, 10:34 PM
robp
Thanks for the info. I kind had that same feeling. but am running a graup 12-8 3 blade. I'm up around 6,000 ft cold day and other day the motor tacked 9280. I thought this would be good and unload in flight to about 10,000 At sea level I would probably need the prop you mentioned. Got any good tips will put them to use.
R Palmer
Old 03-13-2006, 10:36 PM
robp
Thanks for the info. Will look it up as soon get this off in the mail
R Palmer
Old 03-13-2006, 10:52 PM
w8ye
My Feedback: (16)
w8ye's Avatar
There's nothing wrong with 9280 on the ground.
What about valve adjustment. If there's too much clearance, it will slam things around and cause unnecessary wear.
Valves should be .002" to .004"
Enjoy,
Jim
