Bending small tubing
Reply
Old 03-13-2006, 05:10 PM
redfox435cat
redfox435cat's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Bending small tubing
I got 3 vipers now. one for fun and a couple to race with. With the stock engine mount you have to go out the side with the fuel tubing. Anyway this is a real tight bend. Any suggestions on making tight bends in 1/8-5/16 brass or aluminum tubing without chiggering it up
redfox435cat is offline
Old 03-13-2006, 05:27 PM
touch and go
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Bending small tubing
One way to bend such tubing is to get a tool made for the job. One I use is simply a stout spring the inside diameter of which is about the same as the outside diameter of the tubing; just put the tube inside the spring and bend away. Once bent like you desire, simply remove the tubing from the spring. I believe that Tower sells sets of these tools for different size tubing. Another way is to put a piece of cable in the tube and then bend it; when bent properly pull out the cable.
touch and go is offline
Old 03-13-2006, 05:53 PM
piper_chuck
My Feedback: (12)
piper_chuck's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: touch and go
You mean these things? http://www2.towerhobbies.com/cgi-bin...?&I=LXR791&P=7
I've got a set, they work pretty well.
piper_chuck is offline
Old 03-13-2006, 06:06 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Or do you mean these Dubro benders?
http://www2.towerhobbies.com/cgi-bin...?&I=LXE228&P=7
Enjoy,
Jim
w8ye is offline
Old 03-13-2006, 07:16 PM
redfox435cat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
right on. I figured something had to exist Hopfully no more pin holes in my fuel line from dork marks[:'(]
Old 03-13-2006, 09:26 PM
R8893
My Feedback: (20)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you are not already doiong it, you can anneal the tubing to make in soft and easier to bend. Heat it orange with a propane torch then immediately quench in water. In this state it can be bent with your fingers.
R8893 is online now
Old 03-13-2006, 09:51 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bend carefully or your tubing will develop a kink that cannot be removed.
Enjoy,
Jim
w8ye is offline
Old 03-13-2006, 09:54 PM
RC Stout
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
R8893, after you anneal and bend the copper tubing must you harden it again?
RC Stout
RC Stout is offline
Old 03-13-2006, 10:28 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not unless you want to.
w8ye is offline
Old 03-13-2006, 11:10 PM
Dsegal
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Go to http://members.aol.com/harryhig/Tools1.htm and see the Biso Tubing Bender. I usually insert a length of nylon string trimmer line into the tube to add some internal support.
Dsegal is offline
Old 03-14-2006, 12:18 AM
50+AirYears
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DuBro also has a tubing bender for 1/8" brass tubing that seems to work real well. In fact, on the few times I've used it since I bought one, it seems to do a smoother job than the spring benders I've had since my college days.
50+AirYears is offline
Old 03-14-2006, 07:02 AM
BillS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Surprised that no one suggested using soft tubing for the vent line. Half the problem goes away without any effort.
In a pinch I have used electrical wire inside of brass tubing to prevent collapse. My fuel feed line is always straight.
Bill
BillS is offline
Old 03-15-2006, 11:58 PM
treedog
treedog's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
last idea and its guarantied . fill tubing with fine grain sand and seal both ends then bend it on a screw the angle and tight a turn as u need slowly.
treedog is offline
Old 03-16-2006, 09:12 PM
redfox435cat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
tried annealing it just for S+G's and it worked very well. It's been 10 yrs since high school metal shop. Just curious how to re harden it. is it just heat it up and cool it real fast in water, I thinking that is what makes it brittle, or were hardening powders involved. either way it seems strong enough to hold fuel. Though this dubro bender make this pointless, works great, but we got nothing but time right
Old 03-17-2006, 10:57 AM
w8ye
My Feedback: (16)
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The fuel tubing is softened (annealed) by heating and quenching.
To harden the brass, it must be work hardened.
K&S sells copper tubing also but it too is rather hard.
w8ye is offline
Old 03-18-2006, 09:37 PM
RC Stout
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks everyone for all the great posts, I've decided to buy the DuBro tube bender. I already have the spring type of tube benders, but I don't like them.
RC Stout is offline
