Hinge slots
Reply
Old 03-18-2006, 10:24 PM
RC Stout
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hinge slots
When do you cut your hinge slots? before or after covering? I usually cut mine before covering then I hunt for the slot and use a heated Exacto knife and melt the covering.
RC Stout is offline
Old 03-18-2006, 11:17 PM
khodges
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Hinge slots
I usually cut my slots after covering (or drill my hinge-point holes). No particular reason, that just seems how it turns out. I will determine where I want my slots (or holes) before I cover it, that way I can be sure I miss rib attachments and such.
khodges is offline
Old 03-19-2006, 10:36 AM
redfox435cat
redfox435cat's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it's easer to do them after covering. In a perfect world your covering job wouldn't effect the pieces being covered, but in the real world you'll probably put a very slight warp in at least on piece so getting it to re-line up after you've covered the piece could become a problem
redfox435cat is offline
Old 03-19-2006, 11:51 AM
Dsegal
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I cut all slots before covering and make tick marks on the plan so I have no trouble finding the slots after the covering is on. I slit them open with a #11 blade and use a 15W soldering iron to seal the area around the slot.
Dsegal is offline
Old 03-19-2006, 01:58 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I cut 'em before covering (as indicated on the plans), then cover it. Finding the slots is easy if you use a straight pin or gently cut along the area with a # 11 blade - once you cut through the covering and hit the slot, the knife slides in easily.
tailskid is offline
