My repaired OS engine won't stop running .
Reply
Old 03-20-2006, 09:18 AM
Hobie
Hobie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default My repaired OS engine won't stop running .
Howdy all .
At the end of last flying season I broke the crankcase on my OS .46AX in an inverted dumb thumb crash [:@] . I finally got around to putting a new crankcase on it and fired it up yesterday . It started easy ran good I tuned it back up sounded good but it won't quite running with the carb all the way closed [] .Any ideas on what could cause this ? I am assuming it must still be getting air somehow . Any suggestions on what to look for ? Thanks in advance . I have a Sig 4* .40 ordered from Tower for my birthday and I want to make sure this engine is good before putting it on a new plane . Thanks .
Bruce
Hobie is offline
Old 03-20-2006, 09:32 AM
AllTheGoodNamesAreTaken
My Feedback: (180)
AllTheGoodNamesAreTaken's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: My repaired OS engine won't stop running .
One method I've used in the past to find air leaks is to use WD-40. With the engine running and the throttle closed, very carefully spray (using the little red hose) a very small amount around the carb base. The WD-40 will be sucked up into the engine and the engine will quit running. WD-40 wont hurt your engine either. If you're real careful, you can pin point the air leak this way. Just don't cut your fingers off with the spinning prop.
AllTheGoodNamesAreTaken is offline
Old 03-20-2006, 09:41 AM
fokker20planes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Everything Clarence Lee has said in his past articles says that it is getting air from somewhere so you are correct. Try where the carb attaches to case. Is the O-ring still there? Try putting a piece of fuel tubing over the needle valve. I wish I could remember how Clarence said you could submerge the engine in water and by pressuring it you find where air is escaping. If I find an article on this I will post it.
fokker20planes is offline
TimC
TimC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've used an unlit propane torch also to find an air leak. The engine must be at idle so the added fuel will cause an rpm rise. This was on a gas engine and probably would not have much effect on a glow engine. I posted before the morning coffee had kicked in.
TimC is offline
Old 03-20-2006, 09:42 AM
bubbagates
My Feedback: (32)
bubbagates's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I also agree, this sounds allot like an air leak. Check around the carb base, the crankcase back plate, the front bearing seal and anywhere else there is a seal that could leak.
If you re-used any seals from the damage then most likely there is your air leak
bubbagates is offline
Old 03-20-2006, 06:25 PM
Hobie
Hobie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys the carb seal is bad I ordered one from my LHS today . Hopefully that will fix it and that is the only air leak .
Hobie is offline
Old 03-20-2006, 06:50 PM
Tall Paul
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I spread a little goopy around the base of the carb body where it fits on the crankcase, just before I push the carb into the crankcase. This seals that leak area.
Tall Paul is offline
